Hydraulics won't hold Ford 3000 Tractor
   / Hydraulics won't hold Ford 3000 Tractor #1
vettegc
Hydraulics slowly leak down when under a load. What do I have to do to fix?
   / Hydraulics won't hold Ford 3000 Tractor #2
There are many posts about this. search and you'll find much info. something is leaking, could be your spool valve or lift piston ring. I'm not familiar with Ford 3000, but I'm sure you have a rate of drop knob right under you seat. Raise something with your 3 point, then close this valve completely tight. If your valve is holding tight and your implement drops slowly then you have a small leak in the seal. changing seal is easier on 1000 series than some of the older design. if your implement does not drop then I'll look elsewhere.
JC,
   / Hydraulics won't hold Ford 3000 Tractor #3
same question posed as in the hyds forum?
..same answer
soundguy
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
