hydraulics question (tie'ing together)
   / hydraulics question (tie'ing together) #1
bomrat
toro 3050 reel mower
hi, i have a toro lawn mower. it uses 3 hydraulic motors to run 3 separate reels. each real is .43cu. in/rev on 2000psi.
i want to run a single motor. larger of course. to run one pulley.
the setup has 3 separate circuits to drive the motors.
can i just tie the outputs of the circuits together and run them into one larger motor?
the output circuits are already tied together and run back to the reservoir
and what motor size would your run?
thanks
   / hydraulics question (tie'ing together) #2
As the displacement gets larger, the rpm decreases. You will have to step up the rpm via pulleys. You should be able to feed all three into one hose for the larger motor. A manifold with three in, and one out. One hyd motor with a displacement of around 1.29 cu in. at 2000 psi.
I believe someone on here has already done something similar.
hi, ok, i've been trying to find a motor that is .43cu. in rev on 2000psi
everything i can find is listed in different specs.
most motors i find are in gallons per minute.
how can i convert or find what i need.
i am hoping i can find something that will run at
1.29cu in at 2000psi and around 700 rpm.
thanks
   / hydraulics question (tie'ing together) #5
there are 231 cubic inches per gallon.
so if you have a motor with 1.29 CIR (cubic inches per revolution) operating at 700 RPM the formula is:
1.29 CIR x 700 = 903 cubic inches per minute divide by 231 = 3.91 GPM
If the motor data gives flow in GPM Vs RPM
multiply the flow by 231 and then divide by the stated RPM will give you the CIR.
NOTE: NONE of these calculations take ineffiencies into account.
Roy
hi i found the pump specs. and please verify my math on this.
.99 in/rev 2850 rpm max pump (this is a 2000psi pump)
so:
( .99 x 2850 = 2,821.5 ) / 231 = 12.21 gpm.
am i right?
thanks
   / hydraulics question (tie'ing together) #7
Depends what "gallon" you use, USA is 231 cu in and Imperial is 277.4 cu in.
You'll have to factor in what measurement the pump manufactures used.
well, i guess its us gallons.
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
2005 KENWORTH T800 (A53843)
2005 KENWORTH T800...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
