Hydraulics Question: One-way cylinder, two-way system
   / Hydraulics Question: One-way cylinder, two-way system #1
jhansen17
Omaha, NE
John Deere 630
Silly question: Can I use a one-way cylinder with my two-way system? Is it just a matter of connecting the one hose to one of the sides of my outlet (I just have one remote) and if I don't like the way I have to move the lever moving it to the "other side" of the outlet? Or do I need a two-way cylinder to use with my two-way system?
   / Hydraulics Question: One-way cylinder, two-way system #2
Yes, you can use a SA cyl with a DA valve.
Will the SA cyl always have a load to retract the cyl.
You can plug the unused work port.
You could use one port and connect the other work port to tank.
   / Hydraulics Question: One-way cylinder, two-way system #3
Yes
I just use one of the pair when raising the snowplow with a one-way cyl.
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
John Deere PT Land Leveler (A50123)
John Deere PT Land...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
