Hydraulics on KB2475 getting extreamly HOT
   / Hydraulics on KB2475 getting extreamly HOT #1
Streetglide09
Central, Pa
2013 Kioti CK30HST FEL/BH
Ok I'm a newbie, I've been looking in the Hydraulics Forum and haven't been able to find anything as of yet so here is my question I have a CK30HST with 12 hours on it and been using the backhoe mostly, It seems to work fine but after about an hour or so I start to smell odor of grease/hydraulic oil and the cylinders on the boom and dipper are very hot almost to the point of not being able to lay your hand on them for very long. I've checked the other cylinders and they seem to me to be normal warm but not hot. I've looked for leaks and checked the level of hyd oil and all seems to be normal. I called my local dealer where I bought the tractor and after the 3rd guy that I talked to said he has no clue and to just run it as long as the hoe doesn't hick-up. My thing is this I don't want to burn anything up.
The dealer said it shouldn't hurt anything and they would look at it when I bring it in for the free 50hr. service. I just wish they weren't so far away (50 miles)
If anyone has any suggestions I would greatly appreciate it.
Harley.
   / Hydraulics on KB2475 getting extreamly HOT #2
If the cyl are bypassing, the cyl will heat up. Leaky piston seals.
Do a cyl test and a pressure check.
Does you relief valve work with those two hot cyl.
Do you have any restrictors in your BH hyd.
If you use an heat gun, you can see where our hot spots are.
   / Hydraulics on KB2475 getting extreamly HOT #3
Does tractor have an hyd oil cooler & if so is it clean? I think the over heating problem could possibly be either a faulty relief valve or possibly HST trans if trans is being operated. I think the service department needs address overheating problem as excessive heat is detrimental to hyd seals & system.
   / Hydraulics on KB2475 getting extreamly HOT #4
Streetglide09:
There is probably nothing to be concerned about. If you put your hand in 140 deg F water you will suffer second or third degree burns in about 5 seconds; 140 deg is the temperature of hot water coming directly from typical residential water heaters. So it sounds like your cylinder is well under 140 deg F.
The temperature at which hydraulic fluid begins to rapidly oxidize or becomes too thin to provide adequate lubrication varies with composition, viscosity, and brand, but 165 deg F is a commonly accepted temperature for even generic fluids. The best place to take the temperaure is at the junction block where the FEL and/or backhoe are plumbed into the hydraulic system.
You are probably a much better backhoe operator me, but even so I suspect much of the time the dipper and boom circuits are activated they are under a load that causes the relief valve to bypass, which quickly heats up the fluid in the reservoir; the common technique is to give the dipper full flow and then raise the boom as needed to prevent the dipper from stalling. If the operator is too agressive, as I often am, both the dipper and boom stall often, causing the relief valve to open.
That activity, plus the hydrostatic transmission, puts lots of heat into the fluid; I realize that you are not moving all the time, but in most cases you move every few minutes, and even when the transmission is in neutral heat is being generated by the supply circuit for the transmission pump.
If your fluid is, say140 deg F, fluid flowing into the boom and dipper cylinders regularly should raise the metal temperature to say 120 deg F after an hour or so of use. The bucket and swing cylinders are cooler probably because they are activated a relatively shorter time than the boom and dipper cylinders.
JJ's suggestion to get a temperature gun and determine the exact temperature of each surface is a good one to determine if there is really a problem.
Please keep us posted. What you find out will help us all.
Thanks guys I will check all these things. I might just be over acting but spending this kind of money just makes me concerned. If I come up with anything I will post the results. and again thanks for all the help.
Harley.
   / Hydraulics on KB2475 getting extreamly HOT #6
Farmer hit the nail on the head. A general rule of thumb is 100 deg over ambient temp. So on a 100 deg day a system running hard would see almost 200 deg in spots. It is not preferred to see temps that hot but it does happen. Sundstrand used to suggest that as a guideline so don't flame me too bad. In the summer it is not uncommon not to be able to touch hydraulic components. A heat gun or res. temp indicator is really the only good way to tell. I have seen many time units get so hot they discolor paint and melt plastic pieces out of filter heads. THEN you know you have a problem!! CJ
   / Hydraulics on KB2475 getting extreamly HOT #7
Streetglide09 ,
Excerpt from Eaton Hyd:
Temperature
To obtain optimum service life from
both the oil and the hydraulic system,
operate between 49C (120F) and
54C (130F). The maximum oil
temperature normally recommended
is 66C (150F).
   / Hydraulics on KB2475 getting extreamly HOT #8
I thought I posted to this thread already but I must have forgot to hit, 'post quick reply'.:confused2:
AQnyway, I don't know if the CK series allows or provides for routing of the hoe's return line directly into the hydro fill port like on the DK series, but if that is a possibility then by all means contact your dealer and ask them to do the 'kit' which I know does come with the 2475 hoes, and many dealers don't make a point of installing them on the tractors for whatever reason. The kit allows for better return flow and cooler temps of operation so well worth doing it for free IF it is able to be fitted to the CK series like it is on my DK.
Post back results; and I'm sure others may chime in with the answer to the question of the kit's fitment on CKs.
This would solve your 'excessive' heat issue for sure, assuming there is excessive heat or some other fluid flow issue to begin with....
   / Hydraulics on KB2475 getting extreamly HOT #9
You are not losing your mind (at least, this does not represent an example of that). This is a duplicate post also in the Kioti section.
   / Hydraulics on KB2475 getting extreamly HOT #10
Well that's good news; now don't do that again!:eek: I might think I've lost what's left of my mind?!:laughing:
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
RV Hitch (A50121)
RV Hitch (A50121)
