hydraulics let down in ferguson 148
   / hydraulics let down in ferguson 148 #1
breadman13
Maclean N.S.W.
massey ferguson 148
Hi, this is my 1st thread, please help, I have a Massey Ferguson 148 with the square block on standpipe, the lift with slasher on board will not stay up when tractor is switched off, it will hit the ground within 10 secs, when first started will pick up slasher, after that any other time I have to rev tractor, I have new o rings all round as I have had lift cover off & put new piston in ram, with a mirror & torch with tractor going I cannot see any oil spray or leakage but when I stop tractor again it drops straight down again, do you think pump trouble or releife valve or maybe control valve, what else, any help would more than be appreciated, cheers & I love reading threads Harry
Hi, fixed my problem, it was a control valve O ring in the pump, cheers Harry
   / hydraulics let down in ferguson 148 #3
Can you tell us how replacing the o-ring in the pump fixed the trouble in the 3pt lift circuit?
Hi J_J, the control valve in the pump has an O ring each side that holds oil in transport or rise & should let it go in dump, the O ring was letting oil through all the time about half of what was being pumped therefor would not hold, new O rings & now 3 point linkage holds, will not go down overnight, small price, big job, but I got there, cheers Harry
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
UNUSED TELESCOPIC LADDER - 3.2M (A54757)
UNUSED TELESCOPIC...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
