Hydraulics leak down!
   / Hydraulics leak down! #1
myram2500
Summerfield Florida
MF GC2310
I have a 2310, the BH and the 3P leak down when I let them sit or when I use the BH or the Brush cutter.
The outriggers on the BH will loose their height and I have to keep lowering them.
Also with the Brush cutter, I constantly have to lift it to its correct height when cutting.
This is required about every 10 - 20 minutes.
Anyone else have this situation? Is this normal?
Any help is appreciated!
   / Hydraulics leak down! #2
It is normal for some leakage with the cylinders. The three point lift should have little to none. Have your dealer check the rear lift.
It's due for its 50hr service in about 18 more hrs. I will have them check it then.
Other than this and some sweaty hydro lines its been a great unit.
Thanks for the feed back!
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
CAT Skid Steer (A50322)
CAT Skid Steer...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
TRUCK FLATBED (A52472)
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
