Hydraulics leak down Jinma 284
   / Hydraulics leak down Jinma 284 #1
sevenmag83
Jinma 284
I have a Jinma 284 (Agtraxx). Both the 3PH and the front end loader leak down, with or without load, with the engine running or killed. I just bought this tractor and I believe it is around a 2002 model. The engine also has to be at 1/2 throttle for the hydraulics to work. Any suggestins on what could be the problem.
   / Hydraulics leak down Jinma 284 #2
You definitely have some leakage somewhere. Pump maybe worn out. Cyl's might be leaking internally, etc
When the FEL valve levers are in neutral, the cyl fluid is supposed to hold, same with the 3pt cyl. 0-rings, cyl seals, etc.
   / Hydraulics leak down Jinma 284 #3
you might try asking this down in the chinese forum.
until then, how are your loader hyds plumbed?
soundguy
   / Hydraulics leak down Jinma 284 #4
Sounds like you have may have two separate problems.
Loader leak down = Loader control valve and or bad lift or bucket cylinders.
3 Point leak down= The lift piston seal may be bad and or 3 point control valve.
Ronald
Thanks for all the help. I will be working on this weekend and will update. I know the fluid exits the pump, goes through a diverter valve (diverts to power steering slave unit when needed), then branches to the 3PH and FEL. The only thing that makes sense to me is that the cylinders are bypassing but this is my first Chinese tractor and since both are leaking, I didn't know if there could be another problem before ordering seal kits for three cylinders.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
