Loader Hydraulics keep becoming air bound
   / Hydraulics keep becoming air bound #1
odarby
N Ridgeville, Ohio
Ford 1720 & NH TN70
My TN 70 (2000) keeps loosing its hydraulics:thumbdown:. Every time it happens, I check the fluid level and then bleed the system at the nut on top of the filter housing. I alway know its coming, as the strength of the loader decreases and then the hydraulics stop working. The tractor has a Bush Hog 965 backhoe and a Faver grapple bucket. It does seem to leak any amount of fluid... Any help would be very appreciated.
   / Hydraulics keep becoming air bound #2
The logical answer to your constant air in hyd would be a suction leak.
Recommend inspecting the suction tube for cracks, holes, etc.
Tighten all clamps.
You might try some heavy grease on the suction tube to see if the air leak goes away.
Can you look in your tank and see if there are any bubbles.
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
UNUSED MOWER KING SSEFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2013 John Deere 310SK (A47384)
2013 John Deere...
2024 KRUZ Ravens Tri Axle Dump Trailer (A47384)
2024 KRUZ Ravens...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
