Hydraulics just Quit on my 1971 John Deere 410
   / Hydraulics just Quit on my 1971 John Deere 410 #1
gw 1
Cottenwood, Az.
John Deere 410
I started her up, drove over to my fuel tank, started filling the tank, the engine seemed to bog down and then smoothed out and ran back a idle just fine. I finished the fueling, got back in the seat and none of the hydraulics have worked since. I checked the hydraulic pump at the front of the machine and it was fine (I happen to have a new spare that I installed). I checked the filters and topped off the reservoir, everything seemed OK but nothing works but the engine and electrical. I know there is a primary pump for low pressure hydraulics located behind the reverser , but I don't know how to even test it. Any suggestions would be truly appreciated. Jerry
   / Hydraulics just Quit on my 1971 John Deere 410 #2
Sounds like the pump flow got blocked then by-passed perhaps? There are test ports I remember reading one. Have you looked at the connector that drives the main pump off the crankshaft to determine if it is turning?
   / Hydraulics just Quit on my 1971 John Deere 410 #3
Welcome to TractorByNet!
I moved your thread to the Construction Equipment forum. :)
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
Cat TH407C Telehandler (A52128)
Cat TH407C...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
Hyster H225E (A47384)
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
Case 721B (A47384)
Case 721B (A47384)
