Hydraulics Issue or Not
   / Hydraulics Issue or Not #1
rock2610D
Cheyenne WY
2610D
I would like to get everyone's opinion on a hydraulic issue I have.
Background: about 2 months ago I started my tractor and after a short warm up began some loader work. Noticed the tractor was low on power but just thought it need to warm up some more. After about 10 minutes I saw the problem. The lever that moves the 3 pt up and down was in the full down position. That is not bad except my tractor has a lock on the 3 point that can lock it in the up position. The 3 pt was locked and tractor wanted the 3 pt down. After I noticed this I unlocked the 3 point and tractor resumed normal operation with regular power.
Ever since then when operating the loader I hear a thumping sound coming from what sounds like the hydraulic pump. The thumping sound is kinda like what a hammer drill would sound like. I only hear the thumping sound when I am trying to lift the main loader or pulling in the bucket. No thumping sound when lowering loader, or dumping bucket. Also when raising loader, once loader cylinders are fully extended the thumping sound stops even if lever is still calling for up condition.
Also, when loader bucket is full of dirt sound does not happen. Have disconnedted loader quick attaches and tried to determine if thumping happens with 3 pt. It thumps when 3 point is loaded, but only a SLIGHT tapping when raising 3 pt unloaded.
I have not noticed any change in the abilities of the loader or 3pt.
Have I ruined my pump? I hope not. Any advise would be appricated.....
   / Hydraulics Issue or Not #2
Assuming you have a clean pickup screen, my next thought would be a malfunctioning relief valve.
Thanks Lens12, my first thought was screen too. So, I decided to not only clean screen but put new fluid in too. No change.
Relief Valve? please help me here. Where is this dude located and how do I change it out.
Not sure if this helps but I have a Allied 195 loader with levers not a joystick. Is the relief valve in the body of the levers for loader or somewhere else?
Sterling 9500 (A53473)
2008 Ford F-150 XL Pickup Truck (A53117)
2008 Ford F-150 XL...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
DESK (A53843)
DESK (A53843)
