3-Point Hitch Hydraulics help
   / Hydraulics help #1
orchard eric
Western Maryland
Kioti LK30
I took the hoe off of my new LK30 to use the 3-pt hitch... it doesn't raise when I move the position lever to the up position. with the positon lever in the up position, it will raise if I work the FEL. It will work if I turn the directional valve on the block to close... but that prevents the FEL from operating. I suspect that something is plumbed incorrectly with the hydraulic block. Port 4 goes to the loader, port 6 is the "carry over port" and is tee-d to the loader and hoe. Port 5 is only connected when the hoe is not in use. Can anyone confirm that this is correct? picture of hydraulic bock attached.
View attachment DOC040610.pdf
   / Hydraulics help #2
Seen this before. You need to switch the "tank" port and the "power Beyond" port at the hydraulic block. They are reversed.
Not your fault, the manual is mis-leading.
   / Hydraulics help
I ended up calling Kioti and the tech told me the same thing... It came that way from the factory. Evidently this happens often. Thanks for the reply.
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
Club Car Electric Golf Cart (A51694)
Club Car Electric...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
