Hydraulics for New Tractor
   / Hydraulics for New Tractor #1
Snapper Head
South Mississippi
2010 Kubota L3940 HST-3
TBN has been a tremendous help in my hunt for my first tractor purchase. Many thanks.
I plan to buy new, and want to ensure that I purchase enough hydro the first time around. I'm a card carrying idiot, and not very bright, so be patient.:D
I plan to purchase a 40 HP tractor w/FEL, 4WD, Hydrostatic Trans. Dragging 6foot bush hog, disc, box blade, broadcast spreader. Handling round bales with spear, and very possibly a full size grapple for the bucket (if you have ever cleaned up after a major hurricane, you understand the value of a good grapple:thumbsup:).
So - what sort of rear remotes do I need? There are several types, what are the differences? Can I get the fluid power I need from the factory, or am I going to have to do some add-ons (pump, valving, etc.)?
I haven't settled on a color yet, but it will very likely be one green, orange, or blue (if this matters for the hydraulics discussion).
Thanks,
Big Al
   / Hydraulics for New Tractor #2
Every manufacturer offers rear remotes as options, and every one has different cost's. Pick a tractor-then get as may as you can when you order it.
   / Hydraulics for New Tractor #3
These attachments do not of themselves require hydraulics:
- bush hog
- box blade
- broadcast spreader
- Handling round bales with spear
A bucket grapple is typically powered by a third function loader valve / hose kit which you add as a loader option.
A 'disc' may or may not require hydraulics. Depends on if it has hydraulic transport/guage wheels or not.
With the attachment information you provided, you actually may not need any rear remotes. Having said that I would add two standard rear remotes to any new 40HP tractor purchase. Your needs may change. Or you might want a top-n-tilt for box blading, ecetera. When you get to picking a tractor brand, ask your dealer to recommend the best bang-for-the-buck rear remote set up.
Thanks for the replies.
I had planned to get 2 rear remotes, and then after posting this thread I waded into the top&tilt world. As I understand it, a T&T will require 2 rear remotes. For the T&T I can go factory or aftermarket, with the aftermarket being cheaper, but having some assembly required. I have access to a very good mechanic who could help me with the install (translation: my brother, who is extremely capable, will do the work, while I supervise a chair and a 6 pack of beer).
Understood about the grapple setup.
So, if I understand correctly, then I can rely on the factory hydraulic output to cover my plans, even if I go with an aftermarket T&T?
Big Al
   / Hydraulics for New Tractor #5
Big Al
Yes:thumbsup:
Thanks again for the help.:thumbsup:
Big Al
   / Hydraulics for New Tractor #7
Thanks,
Big Al
Good to see someone else from south MS on here.... What part are you from?
From Biloxi. Just bought a 12 acre place for the horses up in NE Stone County.:thumbsup::thumbsup:
MUST buy tractor:D:D
Big Al
   / Hydraulics for New Tractor #9
Big Al
You don't want to go cheap when you do this! Make sure you have a six pack for your brother also:laughing:
6 Pack for him??!!??
He works cheap - 2 beers is all it will cost me:thumbsup::D
Big Al
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
Krause Dominator 4850-18ft (A53473)
Krause Dominator...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51691)
2019 Ford F-550...
