Hydraulics for beginner
   / Hydraulics for beginner #1
bakersfield9n
ford 9n
Just found the site, amazed at the help you guys give out! I am new to the site and just got my first tractor. I am new to hydraulics and am having trouble understanding what all is needed. I understand the pump and sump and control valves. Could some one please explain exactly what all is needed and how they are connected? I am wanting to add a front loader and am comfused... I dont wanna run out and get a pump and controls and next thing break a pump or hose. Please, any help would be appreciate very much. I am just wanting to install a basic loader with up/down and tilt. I am a welder so the metal and fab work is not an issue. But the hydraulic understanding is...Thank you guys very much.
   / Hydraulics for beginner #2
Welcome to TBN. I suggest you look for posts by KennyD and JJ as they are knowledgeable on hydraulics.
I have been searching and will continue, amazing how much you can learn from these guys. I was just wondering what the basic components are besides pump, tank, hoses, ram, and controls... wanting to order, but kinda lost...
   / Hydraulics for beginner #4
Recommend that you pose your question perhaps in a different way; there are many out there that are experts with just about every type/model and year tractor. Can you identify what type of tractor your trying to mount the certain FEL (make/model) to, that will help focus the masses. :thumbsup:
   / Hydraulics for beginner #5
Judging from you name, it sounds like you got a Ford 9N. If so, it would already have a hydraulic pump to operate the 3pt hitch.
Here' s a basic description of the hydraulic system on these vintage Ford tractors:
Hydraulic System
You would basically need to add a 2 spool joystick control valve and plumb it into the existing system. Something along these lines:
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
pclausen: thanks so much for the link. Very good explanation and great pictures. And it is a ford 9n.
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
300# CLUTCH JACK (A53843)
300# CLUTCH JACK...
20702 (A51694)
20702 (A51694)
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
