Hydraulics Foaming (Jinma 224)
   / Hydraulics Foaming (Jinma 224) #1
REM
I'm having problems with the hydraulic fluid foaming out the breather vent. The problem started after having to replace one of the hoses on the FEL which had a leak.
Now, when lifting the FEL and the lowering the fluid foams out the breather. Also, the 3PT will not lift while the FEL is connected. If I disconnect the FEL hydraulics, the 3PT hitch operates without foaming the fluid.
I have drained and replaced the fluid already.
Thanks...
   / Hydraulics Foaming (Jinma 224) #2
</font><font color="blue" class="small">( ... replaced the fluid )</font>
with what ?
//greg//
   / Hydraulics Foaming (Jinma 224) #3
Foam means air getting mixed in, normally susupect the suction side (from tank to pump).
It sounds like you have a resrtriction in one of the quick connects on the loader. What loader are you using? Do you have 3 hoses (not including the 4 to the loader cylincers) or 2?
   / Hydraulics Foaming (Jinma 224) #4
REM,
based on what you said.... as blue chip stated, air is in or getting in the system....
Since it started after the hose relacement, make sure it is not sucking air at the connections of your new hose. You introduced air to the system when the hose broke and when you installed the new one.
Make sure your fluid level is correct. And you will have to operate the FEL to purge the air.... and check fluid level again.
Let us know
Ronald
Ranch Hand Supply
   / Hydraulics Foaming (Jinma 224) #5
Also you have to remember not to lower the fel without the engine running,as that will overflow the hyd.tank! unless you have a fel with "float"
2017 JLG 1932R 19ft Electric Scissor Lift (A50322)
2017 JLG 1932R...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
1272 (A50490)
1272 (A50490)
