hydraulics dip stick
   / hydraulics dip stick #1
Rhon
Bronze Member
Maple Valley Washington
New Holland TC18
I know my eyes are bad but has anyone painted or marked the hydraulics dipstick in any way so you can see the oil on it? I have a bear of a time trying to read it. I've heard about a dye you could add but I'm kinda of leery of putting anything odd in the hydraulic fluid.
   / hydraulics dip stick #2
Get a good quality magnifying glass and check the fluid in strong sunlight-the hydraulic fluid will reflect and glisten, easy to read.:cool:
   / hydraulics dip stick #3
pull it.. wipe it off real good so it has a dry sheen.. stick it and look, front and back. should see the shiney wet part pretty easilly.
some people drill a small letter series drill hole in the middle of the stick to see the oil spot.
wiping and resticking has always worked for me...
soundguy
   / hydraulics dip stick #4
I've drilled a small hole on each line to better see where the oil is.
All but clear fluid, silver stick and bad eyes...I'm doing pretty much all suggestions now. I was just hoping there was an easier way to see it.
   / hydraulics dip stick #6
that's why I rely upon a clean stick .. that shows up a shiney oil on it pretty good.. but you have to pull, wipe, and restick to make that work.
my eyes have been bad since grade school...
my glasses are so thick that ants fear me if i look down while walking around outside.. :)
soundguy
   / hydraulics dip stick #7
I blacken my dipstick with a Sharpie.
Bill
   / hydraulics dip stick #8
Lay the stick on a paper towel. Oil on the stick wil show clearly on the paper. You are probably wiping the dipstick dry before reinserting it to check anyways.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2014 Infiniti QX60 (A51694)
2014 Infiniti QX60...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
