benkapitanec
- Joined
- Jun 22, 2004
- Messages
- 20
I've had my home built logsplitter for about 15yrs. and for the most part it has done what it was intended to do. On occassions I would get into some crotchety pieces and it just couldn't get through them. It had a 4" cylinder with a 11.5gpm pump powered by a 8hp
engine. I have since changed to a 5" cylinder and a 16gpm pump and same engine although I am looking to upgrade to a 10-12hp motor just for ***** and giggles. I have not tampered with the detent valve. I have also added a pressure gauge to the high pressure side of the system, between the pump and the detent valve. My question is, what should be the correct pressure reading to maximize my splitting force. I've heard that the pressure should read 600-650psi w/no load (just cycling the ram). Like I said I've never messed with the detent valves and just assumed that they were already preset with no adjustments required. If anyone has any experience with this, I'd like to hear your advise.
Ben
Ben
