Rotary Cutter Hydraulically Driven Tree Cutting Saws
   / Hydraulically Driven Tree Cutting Saws #1
Bill Hall
Is anyone aware of a hydraulically driven tree saw for cutting cedar, shrub or other small trees that was made in 2003 or earlier? In particular, any such machines that used an overhung load adapter.
If so, I would appreciate any information on such a machine.
Bill Hall
bill.hall@mcafeetaft.com
405-552-2218
Thanks - I'm looking for something that would use a circular blade with an overhung load adapter or bearing block between the blade and the hydraulic motor. I've seen similar machines after 2003, was trying to find an example prior to that date.
http://www.sae.org/mags/sve/TOOLS/7505
In Oklahoma, I've seen advertisements for a Myers Cedar Tree Cutting machine but can't tell from the picture if it uses this adaptor to manage blade vibrations.
   / Hydraulically Driven Tree Cutting Saws #4
Look at these.
Look at these.
Thanks - any chance you know the date for any of the photos? The date is key to me as I'm trying to demonstrate these devices were known at least as early as 2003 preferably 2002 or earlier.
   / Hydraulically Driven Tree Cutting Saws #6
Have you tried to search the "Wayback Machine"?
http://www.archive.org/web/web.php
They have archived the "web", so you can pull up websites and view the content that was on the site on any given period of time. Hope this helps
Internet Archive: Wayback Machine
Thanks - yep, I have that linked book marked. Problem is I need the original URL. Those I do have like Circle 3 Welding, only go back to 2005 or so.
   / Hydraulically Driven Tree Cutting Saws #8
Ok, can't resist. Are you working on behalf of a plaintiff, defendant or doing some sort of due diligence for an inventor?
If only I could get paid to spend time on TBN, well...life would be good!!
If there is more info you can share, the more the better...and I promise I won't charge for my research - unless you are willing to pay!! ;)
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
12-16.5 Tires (A47384)
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
2017 Ford F-450 Altec AT200A 36ft Bucket Truck (A50323)
2017 Ford F-450...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
