Hydraulic
   / Hydraulic #1
Cooperc
Kubota l3650
I have I think a 1992 Kubota l3650
The three point operates normal all the front end loader controls work normal
Except the curl it is extremely slow if you rev the tractor it goes alittle faster but not much
I switched the dump and the curl hydraulic lines and that did make the curl operate normal
Any help or ideas would be appreciated
I have changed fluid and filters about 15 hours ago
Thank you all
   / Hydraulic
As in the quick connects?
   / Hydraulic #4
It's not a real common issue but it could be a blockage in the hose / line...easy to check...
Good Luck...
   / Hydraulic #5
If you switched the "lift" and "curl" hoses and the curl worked okay, did the lift work okay?
What I'm chasing is that maybe the joystick is out of adjustment and not fully activating the curl function when the hoses are properly coupled?
This is common when there is a problem.
I've never had to adjust my lift joystick cable. I've had to adjust the curl joystick cable twice.
   / Hydraulic #6
Forgot to say, welcome to TBN.
Reserved (A53117)
Reserved (A53117)
Kubota BX2230D (A47384)
Kubota BX2230D...
1992 Ford E-350 Ambulance (A51692)
1992 Ford E-350...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
2011 Kubota ZG222 (A50123)
2011 Kubota ZG222...
2003 JOHN DEERE 350D OFF ROAD DUMP TRUCK (A51246)
2003 JOHN DEERE...
