Hydraulic valve
   / Hydraulic valve #1
ducksjunk
Burks Falls, Ontario
yanmar 195D (for sale)
Under the seat on my 195D there is a valve with a large knob, marked open-close. when I close it it seems to block the flow and load up the pump. Can ayoneone tell me its use? /forums/images/graemlins/confused.gif
   / Hydraulic valve #2
May be the drop rate for your 3pt. Closing it closes the ehaust for the lift cylinder
Soundguy
   / Hydraulic valve #3
The valve with the large knob down by your feet is the servicing stop valve to hold the 3ph in the raised position for servicing, and should be fully open or closed. The drop rate valve is a small handle under the seat, (mine is red), for adjusting the rate of descent of an implement, usually about 2 seconds.
   / Hydraulic valve
Yup! I figured out the drop valve okay.
So the other valve should only be closed when the engine isn't running??
   / Hydraulic valve #5
never heard the "fully open or fully closed" info. I always just had it open a little bit so the implements would drop at a not too fast speed. Anyone else agree with the fully open/closed valve adjustment? thanks, brett w
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
HAMM HD+ 120i SMOOTH DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120i...
NEWTON CROUCH 1-04-7612 FERTLIZER SPREADER (A51247)
NEWTON CROUCH...
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51247)
1991 KALYN SIEBERT...
