Hydraulic Valve Control Cables Freezing up
   / Hydraulic Valve Control Cables Freezing up #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I have this most annoying issue with the control cables freezing up. Especially on our open station JD 6200. Can they be successfully removed and lubricated or is replacement, generally the only option? I suspect they got wet and are probably slightly rusted internally.
   / Hydraulic Valve Control Cables Freezing up #2
It's a PITA on my Kubota as well.:mad:
   / Hydraulic Valve Control Cables Freezing up #3
Problem is usually getting the lubrication to the point where they are binding. Companies used to and possibly still do made cable lube that was used on speedometer cables, etc. This lube seemed to help repel moisture and stayed reasonably fluid in colder temps. WD40 is also a water displacing fluid but it seems to get tacky over time.
   / Hydraulic Valve Control Cables Freezing up #4
Its probably moisture in the control valve cups. Lots of info on this in search function?
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
SHOP CABINET W/CONTENTS (A55745)
SHOP CABINET...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
TRANSMISSION JACK (A55745)
TRANSMISSION JACK...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
