3-Point Hitch Hydraulic Toplink
   / Hydraulic Toplink #1
pedalstomper78
Ohio
Case/IH DX33
Hey guys! I've got a 2005 DX 33 with dual remotes and I'd like to go with a hydraulic toplink on it. Anyone have a kit that you know of that includes hoses etc? Also, if anyone has run one, how useful have you found it?
   / Hydraulic Toplink #3
I purchased the hyd. cylindr from Surplus Center, which is advertised on TBN, and then bought the hoses made up at Napa. It was around $175-$200 for the setup. I wouln't have a tractor without a hyd. top link. It works great for boxbladding and makes it alot easier when hooking up implements. You will need to figure out the size and length cylinder you will need. Make sure you get the right type of eyelets at the end of the cylnder. My first hyd. cylinder was from a steering cylinder of an old JD combine. I bought about 2 feet of hoses with the Pioneer fittings X2 and assembled it together. Worked like a charm. Good luck, I just bought a D40 and am putting rear remotes so I can use my cylinder.
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
Sickle Mower (A51573)
