Hydraulic top link
   / Hydraulic top link #1
BenderKC
Kansas City, MO
JD 4310 MFWD HST
Can anyone tell me if this hydraulic top link will work on my 4310 with 3rd SCV - which usually services my 4 in 1 loader bucket? Thanks in advance.
Hydraulic top link
Category 1 Hydraulic Top Link w/ Quick connect Hose Kit
This hydraulic top link is an industrial welded cylinder manufactured to withstand hundreds of thousands of cycles. However, the cylinder is easily rebuildable, should the need ever arise. It is fitted with position indicators that show how far out the cylinder is extended for repeatable positioning and pilot operated check valves to lock the cylinder where you want it to be and eliminate cylinder or control drift.
Cylinders are 21" retracted and 32" extended. They have a 2" bore with a 1 3/16" rod. Please note these are not the cheap red farm type cylinders. They are industrial units built for millions of cycles. Hoses are 4 wire 3/8" industrial hydraulic hose 36" long with a Pioneer (fits almost everything) quick connect fitting. Premium stuff !!
Once you have one of these, you will never have another tractor without one. Hooking up implements is so much quicker and easier. And if you are using a box blade or rear blade, you'll wonder why they don't install them at the factory.
This cylinder is new and unused. I bought several of these and am selling off the ones I don't need. They won't last long.
   / Hydraulic top link #2
I have seen the <font color="green"> JD </font> 4310 compared to my <font color="orange"> Kubota </font>B2910.
The length retracted that I shot for was 18" and 8" stroke. I determined what length I needed I by checking the retracted length of my OEM top link.
   / Hydraulic top link #3
A hydraulic toplink would work with your 3rd scv. As Ron points out, you need to make sure that 21" isn't too long. I don;t know what the reserve is, but they buy it kow looks a bit high to me...
   / Hydraulic top link #4
That HTL looks like the ones that Integrated Engineering and CCM previously sold. The guage decal and the check valve gives it away. However, his Buy it Now price is more than the IE original price. CCM sold the remaining IE inventory for about $150 each. Don't pay more than $150 though. CCM should have new inventory in stock shortly for around $175. The hose kit is valued at $30.
It's a good european made cylinder and should last a long time assuming it's dimensions closely match those of your tractor.
CCM TNT cylinders and kits
   / Hydraulic top link #5
Implement end CAT 1 & 2, Tractor end CAT 1 with double piloted check valve.
19-27.5" - $185
We are filling orders now.
Thanks for your patience.
Mark Carter
   / Hydraulic top link #6
Is that a bushing in the implement end?
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
Enclosed Trailer (A52377)
Enclosed Trailer...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
