Hydraulic Top Link Stroke & Closed Length
/ Hydraulic Top Link Stroke & Closed Length #1
coolnature
Tennessee
NH T4.95, Kubota RTV X1120D, Ford '52 8N
I just purchased a new 8' Gannon box blade and am now in need of a hydraulic top link. With the front horizontal beam of the box blade level on the ground, the length of my manual OEM top link, using the lower of (2) positions, is 26-1/4". If I use the upper position on the tractor, the length of the OEM top link is about 27". I am not sure what the length of the hydraulic top link needs to be closed or fully extended but assume 22" closed and 32" extended. Thanks in advance.
/ Hydraulic Top Link Stroke & Closed Length #2
Typically I would try to provide between 1/2" and 1" more retraction than extension from your 27" operating position, but that may not be found from a std top link selection.
/ Hydraulic Top Link Stroke & Closed Length #3
I found when doing my Hydraulic toplink that I wanted more extension than what a 8 or 10" cylinder would offer me, without sacrificing travel range. I like to tilt down to bushhog over the edge of banks and ponds.
What I ended up with was a 3x12 cylinder that gives me a ~22"-34" range of travel.
I have found that I can do everything I need without wishing for more range. It retracts sufficiently enough to pitch the tail-end of any implement I own plenty high to load onto a deck over trailer, and I have plenty of extension to mow over pond banks, ease hook-up of certain things, etc.
Assuming this is the 95HP NH, If it were mine I'd consider a 3.5" cylinder
/ Hydraulic Top Link Stroke & Closed Length #4
Brian,
How much stroke can you get out of a Cat1 top link? 2" cylinder with say a 21" retracted length. More than 11"?
/ Hydraulic Top Link Stroke & Closed Length #5
Brian,
The way that I build them, a 21" retracted length would get you a 10" stroke, so 21"-31". My std working length for 10" stroke units is 21 1/4"- 31 1/4".
Now if you want to start messing with things I can get a 12" stroke in the 21" dimension, but it causes other concerns that are not favorable.
One of the problems with the ready made units that most places sell is that the base end is not long enough and you can end up being able to typically use the top pin location only. And that is fine for many people, but not everyone.
When you mention 11" stroke, are you looking at the 20 7/8"-31 7/8" units?
/ Hydraulic Top Link Stroke & Closed Length #6
Yes sir, that is what I'm currently using. Working ok for me. I do occasionally get some shudder when first extended from fully retracted. :confused3:
/ Hydraulic Top Link Stroke & Closed Length #7
I had to custom Taylor my 12" stroke cylinder to MY tractor to get 22-34 range. It's close using the bottom hole. No room for error and no guarantee it would work on any other machine. I wanted full 12" range, but as short overall as I could get.
I'd imagine to get 12" range that would clear all possible tractors, you'd want another inch or two to spare.
Brian
I am aware that your lead time for a top link is about 3mos. + another week for shipping. I need to use my box blade well before then. That is why I was trying to come up with an alternative. I don't doubt your product is tailor fitted, well made and will perform, I just need to speed things up on the delivery side. If I am unable to find a suitable unit rather quickly, I will have to wait.
John
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
John Deere 4300 32HP Front Loader Utility Tractor (A61572)
John Deere 4300...
2022 EZ-GO ELITE...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
EZ Trail 3400 (A63688)
