Hydraulic Top link on Mahindra 4110
   / Hydraulic Top link on Mahindra 4110 #1
KENB
CENTERVILLE,TX
MAHINDRA 4110, Ford 2N
I would like to add a hydraulic top link to my 3 point hitch, replacing the manual top link. My question is, where can I buy this hydraulic top link? I hope that I can hook it up to the rear remotes, and use the little lever next to the position and draft control levers to operate the top link. Is it as easy as just replacing the manual turnbuckle style top link with a hydraulic type and hooking up two hoses to the rear remotes of the 4110? Where to buy this stuff?
   / Hydraulic Top link on Mahindra 4110 #2
Integration Engineering at topandtilt.com or CCM at ccmachinery.com
Hardest part for me was making several trips to the Tractor Supply to get hose components - my brain wasn't working.
Mark
   / Hydraulic Top link on Mahindra 4110 #3
Bought mine from CCM for my 3510. I also got the hoses to go with it from them. You are correct about using the lever by the draft control and simply plugging the hoses into the rear remotes. The hoses were complete with the appropriate fittings. It was about a 15 min job to assemble and install. It really makes using the boxblade more productive.
   / Hydraulic Top link on Mahindra 4110 #4
I agree with OsageHill.
I just bought the same setup a few weeks ago. GREAT!
I got the Cat I, 18"-26" and short hose set for my 3510 (same as 4110) Part # at CCM is 06003.
Easy to deal with, and even matches the tractor /forums/images/graemlins/cool.gif
Also makes hooking up with my quick hitch much easier.
If you do a search, you'll find good discussions on hydraulic top links, including the importance of the check valves.
-JC
   / Hydraulic Top link on Mahindra 4110 #5
what is the cost for this?
   / Hydraulic Top link on Mahindra 4110 #6
With shipping and hoses, it was under $200.
-JC
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
3 pt Finishing Mower (A50514)
3 pt Finishing...
CATERPILLAR 289D3 SKID STEER (A51242)
CATERPILLAR 289D3...
TAKEUCHI TL12V2 SKID STEER (A51242)
TAKEUCHI TL12V2...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
