Hydraulic top link on B2910
   / Hydraulic top link on B2910 #1
kch
Bronze Member
I had a Hydraulic top link put on my B2910 by the dealer. When it was installed they had a hard time finding a hydraulic cylinder that would work. Well They got one from Gannon but after using it the sway bars hit the hoses and bend the connector causing the fluid to leak.
Does anyone have a hydraulic top link on a B series kubota and if so what brand and size it the top cylinder???? The dealer can not find one that will work on this tractor.
   / Hydraulic top link on B2910 #2
kch
The problem may be with the way your cylinder is mounted. Here is a picture of how my hoses are routed. Click Here
Post a picture if you have a camera. Someone should be able to come up with a way to help you out.
Do you know what brand the cylinder is in that picture and it's size. On mine , your right, the hoses come off the right side vs. the one your showing comes off the left. Plus the one they put on mine is alot thicker then the one your showing so there is less room.
INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
INGERSOLL RAND...
2010 Cadillac CTS Sedan (A51694)
2010 Cadillac CTS...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
PALLET OF EXTENSION CORDS AND AIR HOSES (A53843)
PALLET OF...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
