brin
Super Member
Have any of you seen this Hydraulink now offered by Agri Supply as an alternative to having to install a hydraulic top link...??
Hydraulink Self Contained Top Link
OK -- I saw it and thought it may be something where you could skip the hydraulic hoses etc. but I guess not from what you fellas are saying...to bad ! I wondered how you could adjust it from the seat of the tractor..I could not get their video link to work so I still can't figure out how it is any better than the standard top link...
I see it as a "quick adjust" top link. Of course, if you have to shorten it to raise the rear of your implement off of the ground... well, you can't. You have to raise your implement and sit the rear on a block (or something), then adjust the link.
There are many uses for a REAL hydraulic top link, however my MAIN reason for buying one is so I can retract the ram and raise the rear of my cutter for transport... in addition to raising the 3ph. (Simply lifting my 3ph does not get the rear of my cutter high enough for transport.) This gets to be a pain with the standard top link... and can't be done with the HyrauLink. That is, unless you set your implement on something the block up the rear. Not what I want to do out in the field when I am ready to come home.
In the meantime, this gizmo has enough adjustment to act as a really good easily adjustable top link, WITHOUT HAVING TO INSTALL REMOTE HYDRAULICS.
