Hydraulic Top Link Conversion Cost Estimate?
   / Hydraulic Top Link Conversion Cost Estimate? #1
UrbannGuerilla
Bronze Member
Allis Chalmers AC5050 / Ford 555B TLB / Ford 6600
I'm just curious.. how much is the "average" cost to convert a manual top link to a hydraulic top link on an older tractor?
1983 AC 5050. 50 hp. Type I/II 3pt hitch.
If I can answer anything that will better help you to answer as best you can, ask me..
**EDIT** - We just got the tractor, but if I am not mistaken, we have a lever by the right front of the seat that operates the "auxillary hydraulics" according to the manual. We're having HD ramps built for the trailer so I have not had a chance to test it out yet.
-UG
   / Hydraulic Top Link Conversion Cost Estimate? #2
average cost of the cylinder $175-$250
average cost of control valve $125-$175
hoses and fittings $100-$150 (possibly less...no QD's are required)
plus whatever it takes to access your pump...i.e., PB kit etc...(for my older Kubota it was about $100
you will also need a way of mounting the control valve...
whatever it costs...if you use any type of rear blade or even a carry all...once you have a hydraulic toplink you will wonder how you ever got along with a manual one...
   / Hydraulic Top Link Conversion Cost Estimate? #3
And if you already have the rear quick connectors and the "lever" to control a dual cylinder, then just the cost of the cylinder per /pine's numbers.
   / Hydraulic Top Link Conversion Cost Estimate? #4
I built my own HTL.
Cylinder from TSC, nothing fancy, be sure and get length you need.
Hoses and fittings from TSC...standard quick connect to rear ports.
Has worked for me multiple years. Figures below are on the high side if you use all standard components from TSC.
John Deere 970 Cultimulcher (A52128)
John Deere 970...
Deere 9965 Cotton Picker (A52128)
Deere 9965 Cotton...
International 4700 Vibra Tiller (A51039)
International 4700...
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
