Hydraulic top and side links. What do I need?
   / Hydraulic top and side links. What do I need? #1
sierradmax
1998 Bobcat 763 & 2009 S-175
Besides the obvious top and side link kit, what's the difference from a power beyond and a rear remote kit? I have a B2320 with the FEL loader. Do I tap off the loader valve for aux. hydraulics? Am I better off with a joystick or double acting valve?
   / Hydraulic top and side links. What do I need? #2
The FEL valve/spools are designed to run the loader, and the remote valve kit is designed to use anything in the back of the tractor, such as the T-N-T, hyd auger, hyd log splitter.
Sure you can use the PB from the FEL to run implements on the back, but each implement has it's own valve. When you are finished with the implement, you then reconnect the loop for the hyd flow.
You can add as many valves as you need, and have the room.
Remotes are better controlled with a lever for each spool. You might want float, detent, and maybe a motor spool.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A52377)
2017 Mack GU713...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
