My 2006 DK35 with 212 hours has a recurring problem.
The Hydraulic System Warning Lamp continues to repeatedly come on after only an hour or so of work. I can be bush hogging or using the loader or the backhoe or even just the rake, matters not.
The problem first began when I ran over a stick and pulled one of the wires lose from the sensor under the tractor. It seemed repaired when I reattached the wire (that is the light went out). But since then, and this may only be coincidence, the light coming on after what I believe to be not much work.
I reviewed the earlier posting of someone having the same problem for any ideas and have tried everything I think. Please see post
http://www.tractorbynet.com/forums/...2.html?highlight=hydraulic+fluid+warning+lamp
What I have tried to date:
1. Thoroughly cleaning the radiator screen and fins by water and air and soft-brush.
2. Keeping higher RPMs 2200-2500 to keep fan running and not lugging the machine.
3. Changed the motor oil, hydraulic fluid, oil filter , and hydraulic filter.
4. Made sure the A-B remote is in neutral (visual inspection only)
5. Made sure fluids are full, and again they were recently changed (2 tractor hours ago)
I am at a loss, only thing I can figure is that I live in a very dusty area (North Florida) and that I will be forced to either run the machine an hour at a time or ignore the lamp, neither of which seem appealing. What say you guys? By the way what happens if one does continue to run the machine when the fluid gets hot enough for the lamp to come on? (Decreased performance, permanent damage, loss of hair)
Thanks ahead of time.
