hydraulic system "strainer"
   / hydraulic system "strainer" #1
Chuk
western PA
YM135
hydraulic system \"strainer\"
I'm planning on putting all new fluids in my new to me ym135. My service manual says to clean out the strainer for the hydraulic system.....but makes no mention of where it is located. Where should I look? The same book says to refill with John Deere 303 oil or equivalent. Is this regular 10wt hydraulic oil?
   / hydraulic system "strainer" #2
Re: hydraulic system \"strainer\"
On my 1700.. the screen is under a triangular cover on the center section.. your -may- be in a similar area.. look around the trans to diff area for a removeable plate.. may have a line going to it.
303 fluid is NOT plain 'jack oil' hydraulic fluid... it is a UTF type fluid.
UTF fluids are for use in common sump transmissions, diffies, final drives, hydraulic systems.. some wet brakes, power steering.. etc.
Again.. my 1700 is a common sump rear end/tranny/hyds.. etc.
Tractor supply sells a Universal Tractor Fluid.. etc. ( hence U T F )
Soundguy
2023 LMC M30018 LOT NUMBER 106 (A53084)
2023 LMC M30018...
2025 Swict 78in Bucket Skid Steer Attachment (A51691)
2025 Swict 78in...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
