Hydraulic Steering Controller Oil Leak - Kubota F3060
   / Hydraulic Steering Controller Oil Leak - Kubota F3060 #1
arto98607
Veteran Member
Southwest WA
Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
The steering controller ( J10500 Steering Hydraulic Pump, as Kubota calls it) is a pretty sophisticated hydraulic steering controller and mine was making a mess due to an oil leak at the input shaft seal up on top.
It's Eaton Orbitrol SK923 steering control unit, made by Sumitomo under a license agreement.
Kubota is not selling these Orbitrol parts at least for my mower anymore, or so I was told recently by a major Kubota dealer. Item 160 "Oil seal K3511-38140" is no longer available individually!
Not sure if the whole $90 seal kit K3511-38390 still is available or not?
The seal Item 160 has these markings: KCR BM 0087A MH 28.6 34.94 3.2 (these are the measurement in mm)
I was unable to find it individually but instead easily found a complete Eaton seal kit on the eBay by searching with the Sumitomo / Eaton Model No. RU051A080F1A SK923
It's a US vendor based in the Midwest and was very helpful and apparently are able to rebuild these units if needed.
I replaced only the "Dust Seal" Item 160 from their Eaton SK923 kit. The old seal had hardened up and also shrunken a little.
Left all other seals as is since they looked OK and it will be pretty easy to access & open up later if need be.
Word of caution: The controller has very tight tolerances and need to be handled carefully when opening up.
I have now found several shrunken oil seals in my 3600 hour F3060 which makes me wonder what has caused that?
I.E. By shrunken I mean some of them even had loose fit in their housing (or bore).
The oil looked pretty clean when I did the first hydro oil change.
It could be due to overheating, stretched change interval, poor seal materials or improper type of hydraulic oil usage by the previous owner - I don't think 3600 hours of use explains it?
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
2023 CATERPILLAR 299D3 SKID STEER (A51246)
2023 CATERPILLAR...
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
T3 Motion Patroller Segway (A51694)
T3 Motion...
