Hydraulic Screen/Filter on 1601D
   / Hydraulic Screen/Filter on 1601D #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
Where is the hydraulic screen/filter on ym1601D? Does anybody have a picture of the location?
   / Hydraulic Screen/Filter on 1601D #2
It is on the left side of the transmission housing, below the brake cover and in front of the axle shaft. 1Danny posted a diagram in your other thread from several years ago, here. If it isn't there, perhaps you have one of the Franken-tractors that sometimes appear, and throw a wrench into repair work.
If so, follow the large suction line back to the transmission. It will be there or immediately adjacent. You should bevable to find a serial number with the model in the transmission case about where your left ankle goes while sitting on the tractor. Good luck, let us know how you do!
i forgot all about the old post. i should have done a better search. i was changing oil, filter, fuel filter, and air filter yesterday on the 1601d and remember that it has a filter screen that need to be cleaned. i also did the same work (fuel filter, pto filter, oil/filter, air filter) on two fords tractors. getting ready for hay season.
   / Hydraulic Screen/Filter on 1601D #4
No problem about the old post (not that I am in any way in charge), I just pointed it out because it might not actually be located where it is supposed to be, if you don't really have a 1601. When there are tractors labeled one thing but actually another, advice or information cannot apply.
Did you get it cleaned?
i will look this weekend when i get back in town. i think the tractor is a 1601d. that is what the stickers on the hood read. but who knows. i have had the tractor for six years. got it from a used car lot. never given me any problems. it don't get used in heavy work, have two other tractors for that. do some light bushhog work around the fruit trees. most of the time it is use as the four wheeler around the farm.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
2025 AGT LRT23 (A50123)
2025 AGT LRT23...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2024 JOHN DEERE 4044M LOT IDENTIFIER 92 (A53084)
2024 JOHN DEERE...
