Hydraulic Remote hook up on Kubota 5030
   / Hydraulic Remote hook up on Kubota 5030 #1
diggdug
Midland, MI
L5030 HSD
OK so I have a BH90 backhoe and to power it they ran a couple of Hydro lines to the rear of my tractor. Now i would like to use a tree planter that needs a remote to lower and raise the unit. Can I just get a valve that hooks into the existing lines? Or do I need to take it in and get the full installation done? I would like to do it as cheaply as possible. Thanks!
   / Hydraulic Remote hook up on Kubota 5030 #2
If there is a pressure and a return line, you should be able to plug in the BH.
   / Hydraulic Remote hook up on Kubota 5030 #3
Assuming that the BH lines are unvalved (power beyond) lines, then you should be able to plug valves into those lines and be good to go. At least I hope so, 'cause I'm planning on doing the same thing on my L4200.
JayC
   / Hydraulic Remote hook up on Kubota 5030 #4
Yes, you can do that very easily.
Manac Walking Floor Trailer (A50322)
Manac Walking...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
Metal Peacock Lawn Art (A51694)
Metal Peacock Lawn...
2018 HINO 195 16FT BOX TRUCK WITH LIFT GATE (A53426)
2018 HINO 195 16FT...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2012 International 4300 Reefer Truck (A53473)
2012 International...
