Hydraulic Quick Coupler
   / Hydraulic Quick Coupler #1
freedy
Hi, can any one tell me why on my John Deere 5225 with 162 hours
I have to already replace the rear hydraulic quick coulpers?
Their the push pull type. I have to allmost slide the tractor to
ingage & disengage them (yes the pressure is off both the valve & cylinder side). The dealership said their having trouble with a few of the models.
Is there a easy fix?
   / Hydraulic Quick Coupler #2
Replace them, it is about as easy as it gets!
   / Hydraulic Quick Coupler #3
Try removing them from the hose and bulkhead assembly and see if they will engage easily. Look inside the female fitting and see if there is any debris/trash in it, if so clean it. Pull the sleeve back and look at the row of bearings in the female part. If the bearings are rusty, they could prohibit connection.
Thanks for the help! I hope the couplers don't need
replacing every 162 hours at $45 a piece.
You sure would think with all the design software
educateded engineers CNC's we could do better.
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
Woods 9204RD-2 Flexwing Finish Mower (A51573)
Woods 9204RD-2...
WOODS RT48.30 LOT NUMBER 231 (A53084)
WOODS RT48.30 LOT...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
