Hydraulic Quick Connect Couplers
   / Hydraulic Quick Connect Couplers #1
pane056
Lake City, Michigan
CaseIH 685 & JD 3320
Hello;
What are the types of Quick Connect Couplers that are on the market?
My understanding is "Flat Face", " ISO ", "Pioneer", "SAE". & John Deere.
Which one will our new 3320 have?
Thank you, nicholas
   / Hydraulic Quick Connect Couplers #2
Whatever you have on the tractor, you will need the same on all the implements.
So if you already have implements that have a certain type QD, then replace the QD's on the tractor.
The QD's can be made by different manufactures, and still work. If they can plug and lock and not leak, then use whatever you can find.
Price range varies quite a bit.
You might try here.
Quick Disconnects > Discount Hydraulic Hose.com
Hello;
Thanks Mr. J.J.
Does John Deere have their own style? I'm trying to figure out what I will need to hook up a Wildkat
Grapple to the JD factory Boom mounted Quick Couplers.
Thanks, nicholas
   / Hydraulic Quick Connect Couplers #4
John Deere used to but not sure on your tractor. have you tried using John deeres parts look up to if they may possibly show what style they are?
   / Hydraulic Quick Connect Couplers #5
What I can tell is the part number for the female portion (mounted on the tractor) is LVA13231.
If you visit Deere's site, go to the support area, open the Residential section, and do a part number search, you should find an image at least.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2013 Chevy Silverado 2500 HD (A55218)
2013 Chevy...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
