hydraulic Question
   / hydraulic Question #1
mtwap
Madison Heights, Va
7205 CC & Yanmar 1610D
I have a cub cadet 7205 with FEL. The loader works fine no problems but if I raze the 3 point (even with nothing on it) the Hyd scream. (Engine RPM drop 50-100 Rpm) It sounds like its coming from loader control valve . All the lines are right; I just replaced the filters and oil. It has done this since I got the tractor. Any Ideas? Thanks
   / hydraulic Question #2
Is this going on with the three-point lever all the way at the top?
No its dose it all the way up. It lifts ok but I can tell with the drop in rpm that it must be loading up the pump. I need to put a gauge on it but haven’t had a chance. I was also going to disconnect the HYD’s on the loader and see if it still doses it.
   / hydraulic Question #4
Sounds to me like the TPH lever is not adjusted right and not opening the valve all the way. Is the lever a little loose on the shaft?
ron
Well I unhooked the HYD for the FEL and the squeal went away so it must be a problem with the FEL control valve. I picked up a pressure gauge I’m going to try putting it in line before and then after the control valve and see how fast or slow it recovers , I know it’s not as good as a flow meter but for the cost of one of them I can just about replace the Valve.
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
1028 (A51572)
1028 (A51572)
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
