Hydraulic question?
   / Hydraulic question? #1
KICK
Platinum Member
stilinlimbo, FLA
Mitsu 2000, Hew Holland 875, JD 125
got this D2000 offshore tractor, hydraulic pump appears to be on front of engine and has hard plumbing right to gearbox, where I assume the system gets its oil from.
question is::: does this thing have a hydraulic filter anywhere
and: does the gearbox use the same oil as the hydraulic system and if so, what kind of oil do you put in it?
   / Hydraulic question? #2
There could be a screen filter inside the tank that screws into the suction outlet. This can be cleaned an reused. There could also be a screen in the line as it enters the pump. I would use regular hydraulic fluid.
   / Hydraulic question? #3
The transmission uses the same oil as the hydraulics. Don't use a straight hydraulic oil. Use a hydraulic /transmission fluid equal to or better than JD303. Mitsubishi/Satoh & Iseki built tractors owner's manual specified #80 oil. In a cold climate it would be too thick. Most other tractors specify the hydraulic /transmission fluid
use a hydraulic transmission oil better than jd303.??
does this puppy have a filter??
   / Hydraulic question? #5
JD303 is an oil from the 70"s. It has been replaced by better oils. You want something that meets or exceeds JD303 specs. It doesn't have a filter, but it does have a pickup screen in the transmission housing that occassionally needs cleaning.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
Towable Sprayer (A51691)
Towable Sprayer...
Case SV185 Compact Wheel Loader Skid Steer (A51691)
Case SV185 Compact...
2005 International 4200 VT365, Super Cab (A52384)
2005 International...
2004 Wabash National 28ft Van Trailer (A51692)
2004 Wabash...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
