wood butcher
OK...I had way too much hydro fluid in my Ford 1920. It was that way when I bought it. It also had water in the hydro system so I decided to drain the system, change out the filter and refill to the CORRECT level. I did all of that then started the tractor up and no hydraulics...not even the 3-point. I might add I had hydraulic issues before that but I think my 3-point worked. The loader would go up and down when I purchased the tractor a few months back but started to not work recently.
I completely disconected the hydro lines from the lift arms and moved the control lever like I would if I was lifting the loader and just a little bit of hydro fluid came out. So...I dont think the pump is working as it should. I should also note I used a WIX filter, not NH. So, I'm stumped...what might be causing the hydros to not work. Do I need to somehow bleed the air out or something? My Deere was a self bleeding system but I'm not sure about the Ford. Anyone have any ideas where I might start?
