Jaybr
Some of you probably remember my post back in May when I had my CK35 in the shop for leaking hydraulic pump and Kioti refused to cover it under warranty because I had rear remotes.
Well, I've had the tractor back since the last week of May, all I've used it for in that time is to mow the lawn a few times. (<45 minutes per mowing)
Yesterday I removed the finish mower and hooked up the 5' brush mower and ask my son to mow the sides of the driveway. It only takes about 30 minutes to mow, and before he finished the hydraulic pump started leaking again.
So the tractor has a brand new $1200 pump, I've done no work that taxed the hydraulics (backhoe or FEL have not been on the tractor), have about 5 hours on the new pump, and it's blown a seal.
I'm trying to think positive in this situation, hoping that maybe this time Kioti will realize that the last pump problem was caused by something other than the rear remote valves and I'll get it fixed and a refund for the work in May.
I'm not a tractor engineer, but I'm thinking maybe the relief valve is not working? Maybe something in the power steering is causing excessive pressure? It did blow a power steering line last year, and I didn't use it much since replacing until April when the first pump problem appeared.
The only thing in common with this time and last was the PTO was running both times.
Since the last time I've been paying close attention to noises, and I never hear any squeel or whine in the hydraulics like I used too. I haven't had any hydraulic implements attached, but from what I remember even if you turn the steering to full stop you'll hear some squeeling which I assume is the pressure relief valve.
If the valve is stuck closed, this may explain a couple things,
1. Why the dealer never noticed that the rear remotes where engaged
2. Why the dealer claimed the pump overheated in 2-3 minutes while Kioti claimed it would take 15.
I'll be calling both the dealer and the tech guy at Kioti tomorrow morning.
