Hydraulic pump
   / Hydraulic pump #1
ebeacham
Southport NC
TYM 723
Hey Guys,
Just wondering wether or not any of you have found aftermarket high performance parts for your Mahindra. I would really like to increase the output of my hydraulic pump because I am going to set up my loader to use skid steer attachments. I am also looking for someone who can build ( or sells )a quick disconnect for the ml 112 loader.
   / Hydraulic pump #2
Mahindra recently introduced qucik attach buckets and implements as well as skid steer compatible buckets and attachments. These are available for the ML112 loaders as well as most other FEL models.
   / Hydraulic pump #3
where on the net does one check into and can "see" these new quick attachments?
   / Hydraulic pump #4
can't answer your question about the main 7.8 GPM pump.. I can tell you though, I have a prototype PTO pump and tank system that I am getting reay to try out as soon as we see sunshine.. Enough rain already..
   / Hydraulic pump
Could you please post a link to see this equipment?
Thanks,
   / Hydraulic pump #7
Eric,
To be nice to Mahindra, after many complaints and about two months time, I was told to bring the tractor back to the dealer for this pump install. They had it about a week and did the install. Brought it home, pouring rain and tested it quickly.. 9 feet deep in virgin soil, about 6 minutes. It does act and operate almost 100% as a full construction backhoe. I was quite pleased with that little test.. We have had 27 days of rain in 32 or so days. So the machine sits. We, finally have had 5 days of little to no rain. Been staining house and until this is done. I'm not near the machine w/backhoe hooked up. I did spend three days and hog mowed 19 acres of hilly fields. This 4110 is exemplary in this mode.. When finished staining, I have a 60 foot ditch to re-route in another direction. I'll let you know how the hoe works then as this is tough digging in this particular area of our property.. I believe this 11 ft Bradco and this new pump set up will work just fine with no hic-cups or problems. I also received an e-mail today, that this particular PTO pump/tank system is a new option being offered or very soon to be offered.. I wouldn't have a clue what costs would be, but, I have to say whoever designed this system, took their time and is designed very well. They very easily could have used polyetheline tank or similar. No go, they used 1/4 inch steel and all in this design is bullet proof or damned close to it. If interested, e-mail Mahindra marketing and see what they can tell you. Now, I've heard about a better designed FEL and quick attach systems for same, been looking on the web and haven't found or seen anything yet. Maybe something will be available soon. I would be interested in a new FEL tower system if it allows more line of sight and possibly more lifting power. Quick attach is also very high on my lists..
   / Hydraulic pump
Thanks for the reply, let me know if you find out anything. If Mahindra does not come up with anything for a quick attach or if it is too expensive or incompatible with SSL stuff then i am going to have something fabricated.
   / Hydraulic pump #9
finally tried the PTO pump, ripping roots that were so old and knotted together,I thought I was tearing through a braided rug. About1200 engine rpm and this thing did great. Only dug down 18" and cut 40' through this mini jumgle. Did a great job that new pto system
   / Hydraulic pump #10
Mahindra has a line of SSL attachments. Bale Spear, Pallet Forks, etc
ROCK PICKER (A52472)
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
