Hydraulic pump upgrades
   / Hydraulic pump upgrades #1
Brighton, Michigan
TYM T574 HCAB
Anyone done pump upgrades to newer tractors? Looking to increase from 9.5 to maybe 12-13gpm.
   / Hydraulic pump upgrades #3
Pump capacity increase from 9.5 to 12-13 gpm will increase speed of hydraulic system reactions but not increase capacity of lifts much, which are a function of hydraulic cylinders installed, not pump flow. A new pump will be expensive relative to operation speed increase.
Speed increase is ok. Mainly it will allow you to use better attachments on the front vs using only PTO attachments. Lift capacity is dependent on cylinders diameter and overall pressure, not flow. Flow does help doing 2/3 things at once.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
UNUSED LONCIN 90 PLATE COMPACTOR (A51248)
UNUSED LONCIN 90...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
