hydraulic pump size
   / hydraulic pump size #1
Lbuddy
I have a 1980 Kubota L245DT with FEL. Hydraulic pump is mounted off front shaft of engine and is made by Webster. There is no tag or model # on pump. Key sheared and ruined shaft. Can anyone give me an idea of pump size so that I can replace w/o OEM thru Kubota?
   / hydraulic pump size #2
Does the pump also provide flow for the power steering? If not, a simple
pump that delivers 6 or 7 GPM at 2000 psi would be about right. Since
pumps are sold specced as a volume per revolution, calculate what you
need for that flow at the full engine RPM (prob 2600).
I don't know your tractor, but later Ls used a dual pump on the same
shaft for the PS and implement flow. If your machine does that, it will
be more complicated.
   / hydraulic pump size #3
Is the pump ran off the crank or the side of the engine. If it is self contained and only runs the loader, any pump of the same size will do. I wouldn't worry about going through Kubota, just be another price increase. Bring up webster pumps and match it.
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
