hydraulic pump driveshaft removal 555
   / hydraulic pump driveshaft removal 555 #1
x2305
Poland ohio
BX23 Ford 555
The u-joints are bad on the hyd, pump driveshaft on my ford backhoe 555. Is it possible to remove the shaft without removing the baffle plate that goes around the driveshaft? I have been studying it and cant see how the plate comes off without removing the hydraulic cooler. Once I remove the bolts from the crankshaft, will it move forward enough to make enough room to pull the shaft out from the back?
   / hydraulic pump driveshaft removal 555 #2
I have a 555B. It does not have the baffle plate like your 555, but when I recently tried to remove my shaft, it cannot be done without removing the cooler lines at the bottom of the radiator. You have enough room to disconnect it from the front pulley and can get it sideways to the point is almost comes out, but the cooler lines keep you from getting that extra "1/2" to complete the job.
I don't have the cooler lines, is that because it is a manual tranny? So a piece of cake , right?
   / hydraulic pump driveshaft removal 555 #4
Can't save with total certainty, but it is only about a twenty minute job to remove the 4 bolts so give it a try.
2015 MACK GU (GRANITE) INOPERABLE (A45046)
2015 MACK GU...
2018 FORD F350 SUPER DUTY (INOPERABLE) (A45333)
2018 FORD F350...
2008 WELLS CARGO 16 T/A ENCLOSED TRAILER (A45046)
2008 WELLS CARGO...
2011 WESTERN STAR 4900 (A45046)
2011 WESTERN STAR...
2005 IMS 5012 LP VERSI DREDGE (A45046)
2005 IMS 5012 LP...
2006 PETERBILT 379 (A45333)
2006 PETERBILT 379...
