Hydraulic pump and motor info needed
   / Hydraulic pump and motor info needed #1
vpd66
Bronze Member
central wisconsin
Case 411b tractor, Dig-it backhoe, John Deere 318 tractor
Hello,
I'm looking for specs on a Sundsrand Variable axial piston pump. The numbers on the pump are: 15-2229 CCW A-94-21-14337
I also have 3 Parker/Nichols wheel motors #114-4-G5-0-02 12-94.
I did some searching online and came up with nothing. I'm looking for GPM, speed, torque, all the good stuff. I salvaged these off a Toro 3 wheeled commercial reel mower. I went to the Toro site but it didn't give me any spec on the components either. Any help will be appreciated.
Thank you, Vince
   / Hydraulic pump and motor info needed #3
If you know the model of the reel mower that is probably the easiest way to find that information. You can just call toro then or look it up online.
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
Broce KR350 (A50123)
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
