Hydraulic problems YM187
   / Hydraulic problems YM187 #1
Whiskey
Platinum Member
Florida
YM 187 Yanmar / JD 790
OK, bear with me this is my first post and if it sound's like I have no clue what i'm talking about it's because I don't /w3tcompact/icons/grin.gif my 4' bush hog will come up all on it's own there is a set pin on the hydraulic guide and if it happons to pop past that I'll be mowing along and look behind me the mower is off the ground. Even with the tractor off and the hydraulic lever in the down position if you tap it with a finger it springs straight up to the back of the guide, so I would assume that something under the seat in the little do-hickys that operate this lever is not holding
If anyone out there would have an idea or something I could try (even though I said do-hicky I'm not that bad with a wrench in my hands....really I swear!!!)
Whiskey
   / Hydraulic problems YM187 #2
Sounds like you need to tighten friction on lever.If it has a bolt with a spring on guide,tighten nut until it stays where you set it.If there is no adjustment on guide then check where shaft that lever attaches to goes into housing.There should be 2 nuts on shaft.Outer 1 is lock.Loosen lock nut and tighten inner nut until lever stays in set position.Retighten lock and you're done.
TBrad:
Sorry it has taken me so long to say thanks for your imput. I mowed the pasture last weekend and did what you said, worked like a champ!!!!!
Whiskey
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2007 PETERBILT 379 (A52472)
2007 PETERBILT 379...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
