Hydraulic problems on 186D,
   / Hydraulic problems on 186D, #1
Anonymous Poster
Epic Contributor
All,
I have been very happy with my little 186D and it runs great, but recently, when I've fired it up, the loader has been acting "jerkey" until it warms up, almost like there's air in the line. But then it works just fine when it warms up. It's not been cold her at nights and it's in the barn to boot. This is a recent thing... Also, I notice when I ran it for about an hour, then turned the engine off, I hear what sounds like a punctured tire.. but it's coming from the rear end case somewhere.. so ... I pulled out the hydraulic dipstic.. and oil comes bubbling out, like it's overfilled.. I have NOT put any oil in this thing for quite a while. It's kinda milky like there's water in it.. which is strange, 'cuz there's no water loss in the engine, and I've not had it near water EVER.. I haven't washed the thing since I put the loader on in December (shame on me).. Soooo anyone have any ideas?
Thanks,
Dale /forums/images/graemlins/confused.gif
   / Hydraulic problems on 186D, #2
It sounds like your 186 needsan oil change. /forums/images/graemlins/shocked.gif
Drain the WHOLE tranny of oil.
Remove your screen filter and clean it
and fill with fresh tractor fluid.
I think your filter might be cloged to the MAX.
Try that and see. /forums/images/graemlins/grin.gif
Tractor Ern. <><
   / Hydraulic problems on 186D, #3
Now I don't know hardly anything about a Yanmar, but if it were a Kubota I'd say your transmission vent is plugged. And I'd almost bet that Yanmar has one, too, that mud daubers or something else has plugged up.
   / Hydraulic problems on 186D, #4
Like Ernie says change the fluid and filter. Don’t add....Change. The water contamination is from condensation in the case. Very normal.
Ernie, and Bird were both right.. I changed the hydraulic oil, filter and cleaned the screen (they all needed a change anyway) but it still "whistled" when I turned it off after running it for a while. So I started looking for a "breather" hole. Found it... in the screw on cap for the hydraulic fluid. An itsy bitsy teeny weenie hole.. I really needed glasses to see it... cleaned it out and problem is solved. Thanks guys...
Dale
   / Hydraulic problems on 186D, #6
Glad it was nothing serious.
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2021 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2021 SMITH...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
