Hydraulic pressure loss..
   / Hydraulic pressure loss.. #1
AlRuby
baxter, tn
kubota 3710
I have a Woods BH7500-1 on a Kubota L3600, the problem I am having is that the backhoe will not hold hydraulic pressure. If I raise the boom it quickly falls, if I put down my outriggers and raise the back of my tractor off the ground , the outriggers immediately lose pressure, I have removed the "system relief valve " but didn't see anything wrong with the copper washer or O-rings. The spring inside looks fine but unsure if it is holding the pressure or not. The manual says do not adjust preset at factory. I have removed the "port relief valves" and everything looks good as well. Hydraulics are full and no leaks anywhere. Any idea what the problem could be ??
Hand Truck (A52377)
Hand Truck (A52377)
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
UNUSED PAIR OF FUTURE 7" RUBBER TRACKS (A51248)
UNUSED PAIR OF...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A53472)
John Deere 700...
2018 COLOMBO TM LOT IDENTIFIER 171 (A53084)
2018 COLOMBO TM...
TOSHIBA 8000 BTU WINDOW AC UNIT (A51248)
TOSHIBA 8000 BTU...
