tommott77
- Joined
- May 23, 2017
- Messages
- 111
- Location
- WILMINGTON
- Tractor
- Power Trac 1430 Deutz, Kubota bx1880, CAT 301.7D mini ex
Hi all hydraulic gurus. Looking for some guidance for those way beyond my rudimentary knowledge/skill set of hydraulic power.
I am in the process of purchasing a like new CAT 301.7D mini ex for some work at some property I own and for the neighboring properties of our POA in the NC mountains. I am considering trying to find/build a hydraulic powered mower for the CAT do some light cutting/mowing. Mostly grass and underbrush. Nothing more than 1" thick, or much more than I'd take on with a push mower. Mainly looking to utilize the boom to access hard to reach areas.
Obviously most of what I am finding on the market is for much larger machines with much higher capacities for much larger jobs. The specs of the aux output on my CAT 301.7D a 8gpm at 2465 psi. The total capable flow out of the machine appears to be about 19.3 gpms (the spec sheet I posted below is a bit confusing on how/what all they list for flow rates). I have found a couple heavy duty flail mowers that fit the specs but are insanely expensive, close to half the price of my machine. The smallest capacity rotary cutter I have found calls for a minimum of 10gpm, though they said they can make it work with a direct drive motor for an added cost and I'd need to add a case drain to my excavator.
In doing some searching around here I came across these Power Trac tractors with similar hydraulics specs/output to my CAT mini-ex that run hydraulic powered mowers/brush cuttrers. Their machines spec at 8 gpm at 2500 psi of PTO output. (Here's a link to their website/specs H Class). Other than the metal fabrication needed to allow one of their mowers to mount in place of my bucket on my ex, would their mowers for their machines work hydraulically speaking on my CAT? If so other than the fabrication of the mounting and perhaps some added safety features, hydraulic lines/fittings is there anything else would need to be done to my mini-ex or to the mower to make it all work?
