Hydraulic Port on transmission L4400-1 HST?
   / Hydraulic Port on transmission L4400-1 HST? #1
bozowise
Lubbock, TX
Kubota L4769 HSTC
Does anyone make a plate that would replace the coverplate on the L4400-1 to get hydrualic fittings?
I do not have the factory rear remote valves and there is just a 3 bolt cover plate where they would attach under the seat on the passenger side. From the factory schematic it appears that there are (2) hydraulic lines that tie in on a block if you add the factory rear remotes and a pipe return line/
What I would prefer to do is replace the coverplate with a plate that has (3) hose fitting so I can add a prince valve off this factory location instead of running hoses up to the loader block.
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
