Backhoe Hydraulic PHD / FEL or Backhoe mount?
   / Hydraulic PHD / FEL or Backhoe mount? #1
JohnnyMac
Arizona
Kubota M59 TLB
I need some help in deciding which is the better way to go for mounting a hydraulic auger. The FEL quick attach system looks to be the most stable and easier to change out. The backhoe mount looks to be more versatile but I am worried about the torsion it would place on the backhoe.
I am getting ready to pull the trigger on a M59 TLB so I could order it with hydraulics set up for either attachment. I am looking at McMillen augers, which can also be setup for both mounts.
John
   / Hydraulic PHD / FEL or Backhoe mount? #2
I would think the BH mount would give you freedom to put the holes where you want them with less jockying around.
   / Hydraulic PHD / FEL or Backhoe mount? #3
I don't know about that.
I have looked and looked for one of these, and I know one is in my future, but I think it would be much easier to drive up to the work area forwards, where I can precisely place the auger right above the hole to be drilled.
The advantage of the backhoe is if you want a hole down an embankment or up on a hillside too steep to just drive up.
I am leaning toward mounted on the front.
   / Hydraulic PHD / FEL or Backhoe mount? #4
I agree seems like loader mount would work for 98% of the time quicker and easier. However a mount on the BH would be nice for those hard to reach areas. If funds are not an issue I would get hyd. on front and rear but its easy for me to spend your money:)
   / Hydraulic PHD / FEL or Backhoe mount? #5
I have the Worksaver 714H PHD, which comes with mounting brackets
for the side of the FEL bkt. I adapted mine to the backhoe dipper stick.
With the hoe you have one more range of motion and you can go side to
side without moving the tractor. Worksaver also has an 814H, which is
designed to clamp to the center of your bkt or use a SS plate.
My hoe has no problem handling the torque put out my the PHD. It has
a very long moment arm.
2013 GMC Terrain SLE SUV (A50324)
2013 GMC Terrain...
43002 (A51691)
43002 (A51691)
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
2021 Ram 1500 Bighorn (A52748)
2021 Ram 1500...
Cat 277 Skidloader (SALVAGE) (A50774)
Cat 277 Skidloader...
1995 Polar Tank Tanker Trailer (TITLE) (A50774)
1995 Polar Tank...
